Is it possible to connect and control Sonoff L3 Pro LED strip?
So I am new to Hubitat (managed to set up a few lights and a few buttons and connect them all up). I have recently been given a Sonoff L3 Pro LED strip and RGBIC controller with inbuilt mic. Is there a way to control this through Hubitat? If so, what drivers/apps would I need?
If not could a work around be that I can use a smart plug to turn them off/on and then if I need to make changes use the eWeLink app?
From the research I have done I believe zigbee cannot deal with controlling each individual pixel (for instance, to make use of the mic and music sync function), is that correct? So I assume this would only be able to be activated/modified by the eWeLink app.
To summarise:
Can I connect the Sonoff L3 Pro to Hubitat
If so what drivers/app/process is needed
If no, is there some sort of hybrid work around
Thanks in advance for any help.
Is this a zigbee device?
If it’s using WiFi, that’s typically harder to integrate with, unless there’s an API that’s publicly available.
No, it is a wifi device and seems to need bluetooth to connect it. I'm not sure if this is just for the initial set up of the app though.
If this device is not going to be compatible do you have a suggestion for another set up?
