My main C7 hub is s suddenly very slow to respond on the GUI. ZWave seems to be not working. I've done a shut down and power cut and it's still the same. What else should I try?
When you said cut power, did you shut dow the hub cleanly before pulling the plug. If not try a soft reset to make sure there is no database corruption.
I did shut down fully first. May have to try a reset I guess
Have you looke for ghosts in you Zwave mesh? Or have a chatty device thatβs over reporting? The zooz double plugs used to do that.
