Iris V3 Motion Humidity Sensor Tile(s)
I’m still relatively new to HE and just paired an Iris V3 Motion and Humidity Sensor.
I’m not completely sure if there’s a better Tile option in the dashboards for this. So far, I’ve had to create two separate tiles for this sensor as the main “motion template” only displays motion, battery, and temperature. AFAIK, humidity needs to fall under a separate template/tile.
I also ask because this can apply to different devices as well.
  1. Is there a way to have just one tile that displays all of the information the sensor provides?
  2. Is there a way to combine two tiles into one?
  3. Would a different dashboard (non-default) display more information?
  4. Is this working as intended?
Take a look at this and see if it does what you want:
Thanks neighbor (I’m in Concord.) That nearly completes my inner UI OCD child...
I just would’ve thought this would’ve been something already addressed by the HE team.
