Mine does the correct amount of beeps strangely. I have exit delay set to 30 and entry delay to 20. If I trigger motion right after arming then it only beeps 3 times but if I let it beep a few times then trigger motion to get rid of the lights staying on then the lights go out and it beeps the correct number of times.
I can't help you with the firmware number. My Iris keypad was a v1 which won't work here, so I bought my v2 on eBay just for Hubitat. Never had it paired to Iris, so the firmware version will remain a mystery.
Re: the logs, I believe you just want to make sure it's done doing stuff before you go on. So wait for a pause in the logs.
Excellent; thanks.
I was able to get this to work on the first try with your instruction above and no issues at all with the light blinking continuously. Thanks again!
