Iris V1 Contact Sensors all Dropped Connection
On the 14th I suddenly lost my zigbee network, still no idea why, but in the same day my Linksys Volop wifi mesh suddenly started playing up and to a lesser extent still is.
However I got the zigbee network up and running, everything looked fine, but then few doors and even fewer windows have been opened and only 4 rules have door/window sensors as part of them, so if a sensor said the window was closed I believed it.
Today I noticed that one of the few RM's that use a door sensor had stopped responding, turned out it hadnt reported since the 20th, long story short I began checking the contact sensors and found that since the 14th the Iris v1 contact sensors had all (36) dropped there connection, a large number of them on the 14th but several per day since then, with the last dropping out on the 20th.
For some reason I am having to reset them all, tried rejoining them and although the hub recognised the sensor the sensor kept flashing as if it was in pairing mode and wouldn't respond. The few I have reset and rejoined all seem fine.
Anyone else seen this behaviour?
Any suggestions as to why this happened over several days?
Any suggestions on how I could stop it happening again?
I just look my friend's system with a bunch of iris v1, all connected, something is going on in your system, and it's odd your wifi got weird the same day.
