Iris Smart Button 3460-L
Has anybody got these things to work? I have managed to pair it, but then pressing it does nothing. Thanks.
Perhaps show the rule you are using to control a device and someone might see what the problem is. I don't have any of those buttons but I am using a few of the Iris V1 buttons and they work well. The V2s are standard zigbee so they should work.
I had 3 of these and they paired and worked fine with Hubitat (and ST before).
However, these have the worst button cell battery connection I've ever seen. I found that pressing the button actually can cause the battery to lose contact and the device to reset. The battery tray also barely makes proper contact; one of mine broke while it was still in use on ST. For a while I had a piece of cardboard jammed in there to put more tension on the battery tray, but it would still occasionally disconnect.
All of mine are now in my IOT box of shame.
(The one I had in use I replaced with an Aqara WXKG11LM zigbee button, which works fine with the caveat that you need sufficient Aqara-friendly Zigbee repeaters on your mesh; I use the Ikea repeaters)
I likewise use some V1 buttons and they do work well.
I've got a few spares for sale if anyone needs any.
