I would think this would stick out to me - but for some reason I'm not sure.
So I have a bunch of Iris Outlets - they are all added as devices just fine (both Zigbee and ZWave).
Problem is - I have a floor fan connected to one of them and I can't figure out how to control it in HE. I went into the button controller and it only lets me work with Pico's and Scenes.
What are the steps for configuring buttons / devices like that.
Your Iris outlets should all show up as a smart Switch device. You can then use these devices in any automation that accepts the Capability "Switch" (which is almost everything!)
I just got some - did you add them as zigbee or zwave -is it a choice or can they be added as both? - also for repeating do I add them to both network or will they only repeat the network they are added?
The controlled outlet operates only as a Zigbee device and when paired to your network will act as a repeater. There is a separate Z-Wave radio whose only purpose is to act as a Z-Wave repeater when you join it to your hub (it is not necessary to use the Z-Wave repeater if you don't need it).
