I am moving a Iris leak sensor from the C3 hub to the newer one but each time I try to pair it using the V1 Zigbee option it hangs at the Initializing part. Is there a trick to pairing this? I've done it multiple times now.
I don't remember how I managed to pair it to the C3 hub lol
What model number, 3315-L is the gen 2. If it is a gen 2 just lookup the reset process, I think you hold the little button inside the cover when putting the battery in while your hub is in normal zigbee pairing mode.
Yes, I'm holding the button down each time I put in the battery. Also popped in a new battery for good measure. I'm on channel 19 for zigbee. This is the only one that's giving me the workout so far.
Here's the reset video, the led blinks orangish in the video. I've been able to get it to do that but only very few times, mostly the blue and green. I think it's the same device, different brand.
