So I am using this driver for my Iris Plugs to get additional tools for the Z-Wave Repeater portion.
It seems to be communicating fine, but under the Z-Wave Table for HE after a reboot, these devices are never communicated with, but the moment I force communication via the driver it responds fine. The interrogation of the device shows this:
Any ideas what is causing the "Group 1 not found, configure device!"? I tried clicking the configure on the device page but that does not seem to do anything.
Note: The unused repeaters are not plugged in, the first 5 are 3210-L and the last 10 are 3210-L2, it is weird that the Pace 5268 Gateway Repeater is normally responding even though it is a L2 model, but none of the other L2 models are normally responding. But at the same time, this device has the same issue and says "Group 1 not found, configure device!" after interrogation.
I have 20 of these and 2 of them no matter what I did I couldn't get them to configure the lifeline group. For those two I just removed them from the zwave mesh. I suspect they have a different firmware but it's just a guess.
Yeah idk, if I trust what the driver says, not a single one of the 6/10 I have plugged in from the new set of 10 I got can join the lifeline group, I feel like that is statistically unlikely. Were the trouble plugs for you L2 or just L models?
Yeah that is very odd, everything I have read has said that the L2 models was a refresh in basically firmware only, and supposedly they are rock solid when compared to the L models. Apparently not though...
Do you know any way to force them into the lifeline? Maybe through a Zniffer?
Probably not, but can't hurt unless you end up with a failed pair. If you got a uzb or z stick not a big deal if you do end up with a ghost node since you can remove em easily.
Yeah so I forgot to update this but I managed to fix my issue. I think when I was initially pairing them, I was doing it via extension cord so I could do it quickly, and I am guessing I unplugged them too quick before doing all of the proper initialization. I excluded all of the offending devices and re-included them and now everything is fine.
