I just got a new C-7 Hub and started the process of moving my repeater devices over from Smartthings. I was able to connect my my Iris 3120-L smart plugs as a Zigbee device, but I was have a lot of trouble getting Hubitat to discover the Z-Wave Repeater device. I discovered some helpful suggestions on how to pair the Z-Wave part, where people were suggesting you need to click the on/off button 8 times to get the hub to see the device. I was clicking the button 8 times with the blue light on the device going on and off each time, but I learned that you shouldn't do that. You need to press the the button 8 times really fast, such that the blue light never turns off. When I did that, the device showed up as a Z-Wave repeater in hubitat.
Be careful with using the 3210-L on the Zwave side. If its not running the latest firmware it may cause problems with your mesh. Its discussed in the thread that @ogiewon linked earlier. If its actually an 3210-L2 you can disregard.
Thanks for the warning. I believe it is the 3210-L (not the -L2) and I seem to be running the latest firmware (0x20085010) when I check my Smartthings IDE after pairing. So, hopefully I'll be ok with my Z-Wave Mesh.
It automatically repeats for both Zigbee and Z-wave with no special drivers required for either protocol. The built-in Zigbee and Z-wave drivers are fine, IMHO.
Admittedly I donโt know how the device actually works, but Iโd guess that power is calculated from the voltage and amperage the device actually measures.
I have one device for the Z-Wave Repeater using the "Iris Z-Wave Repeater" device type, and another device for the Outlet using the "Generic Zigbee Outlet" device type.
