What I see is that any interruption to WiFi connectivity causes the hub to permanently lose network. It doesn't seem to attempt to re-establish WiFi periodically. I waited 15 minutes after the network came back: still no connectivity and the radio LED doesn't flash green anymore. Is there any chance the WiFi driver can be made more reliable?
Yeah, I can most likely build in the same sort of check that wouldn't require a reboot into hub itself.
I run the "big antenna", longer range adapter on my hub, but can switch to the "nano" adapter.
I have the same issue, if I disconnect the nano adapter then reconnect it, after the hub has lost the connection, I can see the green light on the adapter starting to flash again. The connection seems to be established but the hub does not ask for an IP so canโt go back on line.
Sorry for digging this one up again. My hub still seems to have this issue with not reconnecting to wifi after any kind of loss of network. Did more recent updates 2.2.9 and beyond solve it for most people? I have the very latest updates.
2.3.0 has automatic reconnect logic whenever WiFi is used. I run my house hub on WiFi, and it made a difference. Same logic can be manually activated with wired connection, but it is not enabled by default. So yeah, please update to 2.3.0 and see if that improves things.
I'm so excited for this fix, thank you! I updated to the new firmware as soon as I read your message @gopher.ny. I reset my network and the Hubitat remained available, so so far so good! Is there any indication in logs that a reconnect was required? If not I'll just assume it worked silently and flawlessly. Thanks again!
