Is that true? So let's say your hub is on a UPS. You shut it down using a rule after a few hours of power out and before the UPS dies. If power resumes before the UPS is dead, I don't believe the hub would restart without power cycling the supply right? How to do that without a separate (say, WiFi) smart plug between the HE and UPS?
Having a WiFi plug available in that instance would give you an extra level of opportunity should you shut down the hub and enough battery remained that a full power down wasn’t achieved.
