Integration with FEIT Electric WIFI Spotlight Camera, Hard Wired?
I just bought a home that has, already installed, a hardwired FEIT Electric Spotlight Camera, outside the front door. I've searched the community and found that FEIT bulbs are known, but nothing I could find on this device. Admittedly it's WIFI and I normally wouldn't consider this for that reason, but seems a shame to rip it out. I've searched the community and compatible devices but found nothing. I can use the app of course when in the house, but was hoping to somehow integrate at least the lights and perhaps the motion sensor portion with Hubitat. Not sure if anyone knows if there is perhaps a generic driver for wifi based devices that might work for either the motion sensor or lights , or, whether there's something I just missed either here, or through a broader web search.
Alternatively, since it's run off of AC power and there's already a well placed box there, does anyone have a recommendation on a replacement camera (even if no spots) that might be a better fit with Hubitat? Or if not with Hubitat, would be better than FEIT?
Any thoughts would be welcome. Thanks.
Unfortunately there’s no such thing, AFAIK.
Some clues - sparse documentation indicates there is some integration with Google Assistant and Alexa.
Some post found (Using Google) indicates some part of it may be Tuya-based.
That's not much to go on . . .
Have you tried to connect to the fixture using the Feit Electric App? That might expose something that isn't described in the documentation.
