Yup, those "Temp sensor is not online, do nothing" messages mean that your weather device was not updating. Glad you figured that out!
The message should probably be changed to "Weather sensor". When I put this app together I copied a lot from another app I wrote that changes light color based on the temperature and I forgot to update that message.
I’ll change that in my copy. We had some showers in the area last night so the lights briefly changed to red a couple of times. I have the weather update time set to 5 minutes. Fun stuff! Thanks for providing some great code!
A curiosity based on my lack of programming knowledge. I wanted to slow the flash rate to 60 seconds so I changed the input limit in your code from 10 to 60. That generated the following error:
app:5782023-03-04 08:36:40.050 AMerrorjava.lang.RuntimeException: CronExpression '*/60 * * ? * *' is invalid. on line 149 (method switchHandler)
I added a line ‘cloudiness=16’ to force the flashing blue, thus the shift in line numbering.
Maybe you could just explain how that schedule command works? I was successful changing it to 30 without generating the error. As an old programmer, I’m mostly just curious.
