Here we are, this works using the built in OpenWeatherMap driver or the "OpenWeatherMap-Alerts Weather Driver". Other drivers should be able to work, possibly with some minor changes.
* John Hancock Weather Beacon
* Reproduction of the John Hancock building weather beacon in Boston
* http://www.celebrateboston.com/strange/weather-beacon.htm
* Copyright 2022 Peter Miller
definition(
name: "John Hancock Weather Beacon",
namespace: "hyposphere.net",
//parent: "hyposphere.net:P's Light Controls",
author: "Peter Miller",
description: "Reproduction of the John Hancock building weather beacon in Boston",
iconUrl: "",
iconX2Url: "",
preferences {
section() {
input 'isPaused', 'bool', title: 'Pause app', defaultValue: false
section('<b>Devices</b>') {
input 'weather', 'capability.temperatureMeasurement', title: 'Weather device', required: true, multiple: false
input 'light', 'capability.colorControl', title: 'Light', required: true, multiple: false
input 'beaconSwitch', 'capability.switch', title: 'Beacon power switch', required: true
section('<b>Settings</b>') {
input 'saturationOption', 'decimal', title: 'Saturation (0..1)', required: true, defaultValue: 0.95, range: '0..1'
input 'flash_interval', 'number', title: 'Flash rate', required: true, defaultValue: 3, range: '1..10'
section('<b>Debug</b>') {
input 'debugMode', 'bool', title: 'Debug Mode', submitOnChange: true
if (debugMode) {
input 'forecastDebug', 'string', title: 'Forecast override'
input 'cloudinessDebug', 'number', title: 'Cloudiness override'
void installed() {
initialize()
void updated() {
initialize()
void initialize() {
if (isPaused) {
unsubscribe()
unschedule()
light.off()
} else {
subscribe(beaconSwitch, 'switch', 'switchHandler')
if (beaconSwitch.latestValue("switch") == "off") {
unsubscribe('updateLight')
unschedule()
light.off()
} else {
subscribe(weather, 'weather', 'updateLight')
subscribe(weather, 'condition_text', 'updateLight')
subscribe(weather, 'cloudiness', 'updateLight')
subscribe(weather, 'clouds', 'updateLight')
updateLight()
void switchHandler(evt) {
unsubscribe(updateLight)
unschedule()
light.off()
} else {
initialize()
void updateLight(evt) {
Float tempOut
List<Integer> hsvColor = null
Float satLevel = saturationOption
if (satLevel > 1) {
satLevel = 1.0
} else if (satLevel < 0) {
satLevel = 0
if (weather.getStatus() != "ACTIVE") {
log.warn "Weather device is not updating, do nothing"
} else {
hsvColor = getColor()
light.setColor(["hue": hsvColor[0], "saturation": hsvColor[1], "level": light.latestValue("level")])
List<Integer> getColor() {
List<Integer> red = [0, 100, 0] // red
List<Integer> blue = [60, 100, 0] // blue
String forecast
Integer cloudiness
if (debugMode) {
forecast = forecastDebug.toLowerCase()
cloudiness = cloudinessDebug
} else {
if (weather.latestValue("weather")) {
forecast = weather.latestValue("weather").toLowerCase()
} else if (weather.latestValue("condition_text")) {
forecast = weather.latestValue("condition_text").toLowerCase()
} else {
log.error("No forecast attribute found for this device")
if (weather.latestValue("cloudiness")) {
cloudiness = weather.latestValue("cloudiness") as Integer
} else if (weather.latestValue("cloud")) {
cloudiness = weather.latestValue("cloud") as Integer
} else {
log.error("No cloudiness attribute found for this device")
//log.debug("$cloudiness; $forecast")
// Weather codes per openweathermap.org/weather-conditions
switch (forecast) {
case ~/.*snow.*/:
case ~/.*sleet.*/:
log.debug("Flashing red, snow instead")
schedule('*/' + flash_interval + ' * * ? * *', 'flash')
return red
break
case ~/.*rain.*/:
case ~/.*drizzle.*/:
case ~/.*thunderstorm.*/:
log.debug("Steady red, rain ahead")
unschedule('flash')
light.on()
return red
break
default:
if (cloudiness > 15) {
log.debug("Flashing blue, clouds due")
return blue
} else {
log.debug("Steady blue, clear view")
unschedule('flash')
light.on()
return blue
void flash() {
if (light.latestValue("switch") == "on") {
light.off()
} else {
light.on()
2023-Feb-28: Updated message for weather device is not updating to more accurately reflect the issue
