I cannot get status on a new hub to install the source for the package manager
Try rewording your issue. Not sure what “cannot get status” means.
HPM Installation - First Time Users
In order to save some space, the video moves at a rapid pace. Use the browser's speed control OR the Pause button on the playback.
Follow the Hubitat Package Manager installation instructions here for step-by-step:
OR, use this Import URL:
https://bit.ly/3VfykH9
https://s.hubitatcommunity.com/hgzsk
OR, this:
https://raw.githubusercontent.com/HubitatCommunity/hubitatpackagemanager/main/apps/Package_Manager.groovy
To add custom app code to your hub:
- Navigate to Settings and ensure the Show advanced/developer options toggle is enabled.
- In the sidebar, find the For Developers section and then select Apps Code under this section. (If you do not see Apps Code, expand the For Developers section. If you do not see the For Developers section, return to the previous step to verify.)
- Select the +Add App button at the top of the Apps Code page.
