Was this implemented ? I am still not seeing ramp rate in red dimmer settings.
@salmanslim Ramp rate is in the current firmware for the dimmer, but it has been there all along. If you are wondering about the 700ms delay that happens from when you push the button and when the light turns on, there is a configuration option in the latest firmware to disable this delay. All of our firmware files can be found here:
https://support.inovelli.com/portal/en/kb/inovelli/downloads/firmware
Thank you Eric. I found those settings under the driver from github and added to HE. I am not using the default driver for inovelli on HE.
