Hi JNS, I'll reach out, but if you want to try one more thing, just to see if this is a universal issue and not one just with my 2 dimmers.
When you are on Green Brightness 1, the LED should almost be imperceptible. I do notice a difference between them all as well, but when I use the dimmer or set LED intensity (just on its own), I am able to go VERY Dim. With the setIndicator, I'm not able to get all the way down to almost 0,
As far as I know setIndicator is used for notifications, not individual settings. What value[s) are you putting in the setIndicator field? What other parameters are you passing?
Maybe @bertabcd1234 can give better guidance I know he has played around with the driver for these devices.
I'm putting 33489232 in the Set Indicator field, which in turn populates parameter16value: 33489232
Like I said, it does everything right, except dimming down past 40%. I mean, it works as expected, except for the dimming part. I can go to 100% and cycle down all the way to (I'd say 30-40% but can't be sure exactly where it is).
this works to DIM down the level to 10% as I've set it, but as soon as the Rule kicks back in, or I edit paramater16 with any other value, the intensity goes back up to around 30-40%
