Sorry Eric did not work, still on same way.
Can you provide the following information to me in a PM? Watch the logs when you do the following and copy and paste them in the PM.
Turn the NZW37 on phsically:
1 tap on
1 tap off
2 tap turn channel 1 on
2 tap turn channel 1 off
3 tap turn channel 2 on
3 tap turn channel 2 off
Turn the NZW37 on through HE:
Parent on
Parent off
Channel 1 on
Channel 1 off
Channel 2 on
Channel 2 off
Wait a few seconds in between actions so they can stand out in the logs. Thanks!
Thanks for the help @emersonvier. We discovered that in certain situations Hubitat too quickly processes commands which can sometimes make the device state not update. Basically it can set the device to on/off and request its status so quickly that the device hadn't fully changed state before sending its status. This has been fixed in the driver with a delay between commands:
Eric, thank you for your work on this. I have this plug too and I love it, even better that you are active here.
I noticed the only Inovelli device left on Amazon is a door sensor?
Really looking forward to see the key fob when it comes out.
I just updated my devices with this updated version of your driver and watched the state change in action on the dashboard tile. VERY NICE! Thank You for the fix sir!!
For the NZW37 Switch Child Device, I simply added the refresh() method immediately after executing the childOn or childOff commands.
This isn't working consistently for me. Are there any other options?
dev:1772020-07-12 06:10:14.023 pm debuginitialize()
dev:1772020-07-12 06:10:14.022 pm debugconfigure()
dev:1772020-07-12 06:10:11.020 pm errorjava.lang.NullPointerException: Cannot get property 'deviceNetworkId' on null object on line 281 (componentRefresh)
I am seeing a similar problem. I saw that there were a lot of "debug" entries for my 4 NWZ37 plugs and after doing some reading I saw that the Eric Maycock driver I had was old and had recently been updated so I removed all my rules involved and removed all 4 devices. I then updated the driver and as stated it created the 2 child devices for the plug automatically. Now those children DO show up a "Generic Component Switch". Upon re setting all my rules, I then saw that in Dashboard when I hit a "Switch" tile, it kept the "hourglass" running, I then had to go in and hit "refresh" on the device page. So none of my rules are working as a result and On and Off shows on the log but it does not change in the dashboard (or trigger the rules) until I manually hit refresh. Any ideas on what may be wrong or do I have to just enter the "refresh" command as shown above?
@wnc.dave @jsarcone I wonder if you have a different version of the plug than I do. Can you install the latest driver from Github and click "Save Preferences"? Then wait a few seconds and refresh the page. Let me know what is in these sections:
Hope this is what you wanted.
2 of the 4 are the "show home" models before they became Innovelli, the other 2 are their first run "Inovelli" labeled ones. The one I posted is one of the later. 7 /17 mfg.
State Variables
- oldLabel :
- defaultG3 : []
- defaultG2 : []
- actualAssociation1 : [01]
- defaultG1 : [01]
Current States
- checkInterval : 10920
- lastActivity : 2020 Jul 14 Tue 3:44:22 PM
- numberOfButtons : 1
- switch : off
original was 6.26.2020. I just update 7.14.2020
Current States
- lastActivity : 2020 Jul 14 Tue 3:47:32 PM
- switch : off
State Variables
- oldLabel :
- defaultG3 : []
- defaultG2 : []
- defaultG1 : [01]
Okay, I loaded it yesterday, your too fast. Give me a couple minutes.
I quickly checked and refreshing is still needed.
Agreed. I fix the child refresh issue but the parent device is still an issue.
So, in the child device driver I put:
void on() {
parent.childOn(device.deviceNetworkId)
parent.childRefresh(device.deviceNetworkId)
void off() {
parent.childOff(device.deviceNetworkId)
So if I turn on child it will refresh and update the parent. However, If I turn on the parent nothing is refreshed.
I will say the new DLH seems to be more responsive but still doesn't refresh.
