I am having an issue with an Inovelli NZW30. I had this running on ST perfectly fine. Today, since I wanted to migrate it to Hubitat, I excluded it from ST and that completed successfully.
I immediately paired it with Hubitat. I went into discovery mode, it found the switch and paired it.
Then I discovered that I needed to install the device drivers first.
So I installed the device drivers for all my Inovelli devices via the package manager. I looked and it still didn't recognize the switch which I wasn't holding my breath for. So I excluded the switch in Hubitat. It didn't work so I "forced" it to exclude. It was no longer in my device list.
Then I went to rediscover devices and it wouldn't find it. I went to the Inovelli site to make sure that I was doing it properly. I even did a factory reset by holding in the up button for 5 seconds (didn't work) then turning off the breaker and turning it back on while holding the up button for 5 seconds. Still doesn't find it.
I was going to ask in the Inovelli forums, but I'm pretty sure that this is a Hubitat question since it did find the same hardware once and the exclude didn't work properly.
I'm hoping someone in here has some advice that will help.....
UPDATE: I got an answer on this via a FB group. I needed to use this instruction to reset the switch which says to hit the up paddle 10X:
I was using this one which says to hold the up paddle while restoring breaker power:
That didn't work.....
