Inovelli Dimmer Red Series LZW31-SN
Hello, recently purchased a HE hub after using ST for many years. I have started to switch my devices over but have got stuck on the first dimmer. I can add it but unable to control in in the dashboard.
  1. Excluded from ST but starting the ST exclusion process and tapping the Inovelli config button 3 times.
  2. Factory reset Inovelli by holding config button for 20 seconds until LED turns red
  3. Add Inovelli LZW31-SN driver code
  4. Add Zwave device in HE, start inclusion process and tap inovelli config button 3 times. HE finds it and I select no security and I give it a name and room.
It shows in the list of devices but I can figure out how to do anything with it. I cant add pictures but just shows 2 buttons that I can't even click on. One named Test Dimmer and one named Inovelli Dimmer Red Series LZW31-SN.
In the device list it shows
Test Dimmer
(Inovelli Dimmer Red Series LZW31-SN)
Inovelli Dimmer Red Series LZW31-SN (LED Color)
(Generic Component RGBW)
Some light bulbs have added just fine but kinda stuck at the dimmer issue and also getting everything to show in Google Home may be a deal breaker, just hoping to get past this one as a I have several of these dimmers.
It could be unrelated, but there was another topic posted recently for the same Inovelli devices....Do you see any errors in the Logs page for your devices?
I don't see anything like that in the logs. I'm sure I'm doing something wrong but they did seem to play nicer with ST.
dev:482022-12-21 09:57:50.882 PMinfoTest Dimmer: Basic report received with value of off (0)
dev:482022-12-21 09:57:50.881 PMdebugTest Dimmer: BasicReport(value:0)
dev:482022-12-21 09:56:44.314 PMinfoTest Dimmer: Power report received with value of 0.0 W
dev:482022-12-21 09:56:44.310 PMdebugTest Dimmer: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 0], rateType: 1, deltaTime: 0, previousMeterValue: [])
dev:482022-12-21 09:56:38.879 PMinfoTest Dimmer: off()
dev:482022-12-21 09:56:38.706 PMinfoTest Dimmer: Power report received with value of 42.6 W
dev:482022-12-21 09:56:38.703 PMdebugTest Dimmer: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 1, 170], rateType: 1, deltaTime: 0, previousMeterValue: [])
dev:482022-12-21 09:56:33.184 PMinfoTest Dimmer: on()
dev:482022-12-21 09:54:57.433 PMinfoInovelli Dimmer Red Series LZW31-SN: Protection report received: Local protection is off & Remote protection is off
dev:482022-12-21 09:54:57.430 PMdebugInovelli Dimmer Red Series LZW31-SN: Inovelli Dimmer Red Series LZW31-SN: ProtectionReport(localProtectionState:0, rfProtectionState:0)
dev:482022-12-21 09:54:55.429 PMinfoInovelli Dimmer Red Series LZW31-SN: Firmware Target 1 report received: firmware 1.41
dev:482022-12-21 09:54:55.420 PMinfoInovelli Dimmer Red Series LZW31-SN: Firmware report received: 1.48
dev:482022-12-21 09:54:55.415 PMdebugInovelli Dimmer Red Series LZW31-SN: VersionReport(zWaveLibraryType:3, zWaveProtocolVersion:6, zWaveProtocolSubVersion:4, firmware0Version:1, firmware0SubVersion:48, hardwareVersion:1, firmwareTargets:1, targetVersions:[[target:1, version:1, subVersion:41]])
dev:482022-12-21 09:54:54.406 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '52' with a byte size of '1' is set to '0'
dev:482022-12-21 09:54:54.404 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 52, size: 1, configurationValue: [0], scaledConfigurationValue: 0)
dev:482022-12-21 09:54:52.405 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '51' with a byte size of '1' is set to '1'
dev:482022-12-21 09:54:52.403 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 51, size: 1, configurationValue: [1], scaledConfigurationValue: 1)
dev:482022-12-21 09:54:50.403 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '1' with a byte size of '1' is set to '3'
dev:482022-12-21 09:54:50.402 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 1, size: 1, configurationValue: [3], scaledConfigurationValue: 3)
dev:482022-12-21 09:54:48.400 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '22' with a byte size of '1' is set to '0'
dev:482022-12-21 09:54:48.398 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 22, size: 1, configurationValue: [0], scaledConfigurationValue: 0)
dev:482022-12-21 09:54:46.401 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '21' with a byte size of '1' is set to '1'
dev:482022-12-21 09:54:46.399 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 21, size: 1, configurationValue: [1], scaledConfigurationValue: 1)
dev:482022-12-21 09:54:44.392 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '20' with a byte size of '1' is set to '10'
dev:482022-12-21 09:54:44.391 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 20, size: 1, configurationValue: [10], scaledConfigurationValue: 10)
dev:482022-12-21 09:54:42.390 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '19' with a byte size of '2' is set to '3600'
dev:482022-12-21 09:54:42.388 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 19, size: 2, configurationValue: [14, 16], scaledConfigurationValue: 3600)
dev:482022-12-21 09:54:40.388 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '18' with a byte size of '1' is set to '10'
dev:482022-12-21 09:54:40.386 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 18, size: 1, configurationValue: [10], scaledConfigurationValue: 10)
dev:482022-12-21 09:54:38.397 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '17' with a byte size of '1' is set to '3'
dev:482022-12-21 09:54:38.395 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 17, size: 1, configurationValue: [3], scaledConfigurationValue: 3)
dev:482022-12-21 09:54:36.387 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '15' with a byte size of '1' is set to '1'
dev:482022-12-21 09:54:36.385 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 15, size: 1, configurationValue: [1], scaledConfigurationValue: 1)
dev:482022-12-21 09:54:34.396 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '14' with a byte size of '1' is set to '5'
dev:482022-12-21 09:54:34.395 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 14, size: 1, configurationValue: [5], scaledConfigurationValue: 5)
dev:482022-12-21 09:54:32.378 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '13' with a byte size of '2' is set to '170'
dev:482022-12-21 09:54:32.376 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 13, size: 2, configurationValue: [0, 170], scaledConfigurationValue: 170)
dev:482022-12-21 09:54:30.375 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '12' with a byte size of '1' is set to '15'
dev:482022-12-21 09:54:30.373 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 12, size: 1, configurationValue: [15], scaledConfigurationValue: 15)
dev:482022-12-21 09:54:28.371 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '11' with a byte size of '1' is set to '0'
dev:482022-12-21 09:54:28.369 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 11, size: 1, configurationValue: [0], scaledConfigurationValue: 0)
dev:482022-12-21 09:54:26.368 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '10' with a byte size of '1' is set to '0'
dev:482022-12-21 09:54:26.367 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 10, size: 1, configurationValue: [0], scaledConfigurationValue: 0)
dev:482022-12-21 09:54:24.366 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '9' with a byte size of '1' is set to '0'
dev:482022-12-21 09:54:24.364 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 9, size: 1, configurationValue: [0], scaledConfigurationValue: 0)
dev:482022-12-21 09:54:22.378 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '8' with a byte size of '2' is set to '0'
dev:482022-12-21 09:54:22.375 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 8, size: 2, configurationValue: [0, 0], scaledConfigurationValue: 0)
dev:482022-12-21 09:54:20.368 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '7' with a byte size of '1' is set to '0'
dev:482022-12-21 09:54:20.366 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 7, size: 1, configurationValue: [0], scaledConfigurationValue: 0)
dev:482022-12-21 09:54:18.362 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '6' with a byte size of '1' is set to '99'
dev:482022-12-21 09:54:18.359 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 6, size: 1, configurationValue: [99], scaledConfigurationValue: 99)
dev:482022-12-21 09:54:16.357 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '5' with a byte size of '1' is set to '1'
dev:482022-12-21 09:54:16.355 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 5, size: 1, configurationValue: [1], scaledConfigurationValue: 1)
dev:482022-12-21 09:54:14.355 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '4' with a byte size of '1' is set to '101'
dev:482022-12-21 09:54:14.353 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 4, size: 1, configurationValue: [101], scaledConfigurationValue: 101)
dev:482022-12-21 09:54:12.351 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '3' with a byte size of '1' is set to '101'
dev:482022-12-21 09:54:12.349 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 3, size: 1, configurationValue: [101], scaledConfigurationValue: 101)
dev:482022-12-21 09:54:10.349 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '2' with a byte size of '1' is set to '101'
dev:482022-12-21 09:54:10.347 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 2, size: 1, configurationValue: [101], scaledConfigurationValue: 101)
dev:482022-12-21 09:54:08.375 PMinfoInovelli Dimmer Red Series LZW31-SN: parameter '1' with a byte size of '1' is set to '3'
dev:482022-12-21 09:54:08.370 PMdebugInovelli Dimmer Red Series LZW31-SN: ConfigurationReport(parameterNumber: 1, size: 1, configurationValue: [3], scaledConfigurationValue: 3)
dev:482022-12-21 09:54:06.341 PMinfoInovelli Dimmer Red Series LZW31-SN: Associations for Group 1: [01]
dev:482022-12-21 09:54:06.338 PMdebugInovelli Dimmer Red Series LZW31-SN: AssociationReport(groupingIdentifier: 1, maxNodesSupported: 5, reportsToFollow: 0, nodeId: [1])
dev:482022-12-21 09:54:05.341 PMinfoInovelli Dimmer Red Series LZW31-SN: Associations for Group 4: []
dev:482022-12-21 09:54:05.338 PMdebugInovelli Dimmer Red Series LZW31-SN: AssociationReport(groupingIdentifier: 4, maxNodesSupported: 5, reportsToFollow: 0, nodeId: [])
dev:482022-12-21 09:54:04.161 PMinfoInovelli Dimmer Red Series LZW31-SN: Associations for Group 3: []
dev:482022-12-21 09:54:04.158 PMdebugInovelli Dimmer Red Series LZW31-SN: AssociationReport(groupingIdentifier: 3, maxNodesSupported: 5, reportsToFollow: 0, nodeId: [])
dev:482022-12-21 09:54:03.555 PMinfoInovelli Dimmer Red Series LZW31-SN: Power report received with value of 0.0 W
dev:482022-12-21 09:54:03.551 PMdebugInovelli Dimmer Red Series LZW31-SN: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 0], rateType: 1, deltaTime: 0, previousMeterValue: [])
dev:482022-12-21 09:54:03.143 PMinfoInovelli Dimmer Red Series LZW31-SN: Associations for Group 2: []
dev:482022-12-21 09:54:03.140 PMdebugInovelli Dimmer Red Series LZW31-SN: AssociationReport(groupingIdentifier: 2, maxNodesSupported: 5, reportsToFollow: 0, nodeId: [])
dev:482022-12-21 09:54:02.595 PMinfoInovelli Dimmer Red Series LZW31-SN: Energy report received with value of 0.000 kWh
dev:482022-12-21 09:54:02.581 PMdebugInovelli Dimmer Red Series LZW31-SN: MeterReport(meterType: 1, precision: 3, scale: 0, size: 4, meterValue: [0, 0, 0, 0], rateType: 1, deltaTime: 0, previousMeterValue: [0, 0, 0, 0])
dev:482022-12-21 09:54:02.150 PMinfoInovelli Dimmer Red Series LZW31-SN: Associations for Group 1: [01]
dev:482022-12-21 09:54:02.143 PMdebugInovelli Dimmer Red Series LZW31-SN: AssociationReport(groupingIdentifier: 1, maxNodesSupported: 5, reportsToFollow: 0, nodeId: [1])
dev:482022-12-21 09:54:02.006 PMinfoInovelli Dimmer Red Series LZW31-SN: Protection command class settings need to be updated
dev:482022-12-21 09:54:01.995 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 52
dev:482022-12-21 09:54:01.993 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 52 with a size of 1 bytes to 0
dev:482022-12-21 09:54:01.940 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 51
dev:482022-12-21 09:54:01.938 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 51 with a size of 1 bytes to 1
dev:482022-12-21 09:54:01.934 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 50
dev:482022-12-21 09:54:01.932 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 50 with a size of 1 bytes to 5
dev:482022-12-21 09:54:01.928 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 22
dev:482022-12-21 09:54:01.926 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 22 with a size of 1 bytes to 0
dev:482022-12-21 09:54:01.922 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 21
dev:482022-12-21 09:54:01.920 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 21 with a size of 1 bytes to 1
dev:482022-12-21 09:54:01.917 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 20
dev:482022-12-21 09:54:01.915 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 20 with a size of 1 bytes to 10
dev:482022-12-21 09:54:01.911 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 19
dev:482022-12-21 09:54:01.909 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 19 with a size of 2 bytes to 3600
dev:482022-12-21 09:54:01.905 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 18
dev:482022-12-21 09:54:01.903 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 18 with a size of 1 bytes to 10
dev:482022-12-21 09:54:01.895 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 17
dev:482022-12-21 09:54:01.885 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 17 with a size of 1 bytes to 3
dev:482022-12-21 09:54:01.878 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 15
dev:482022-12-21 09:54:01.877 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 15 with a size of 1 bytes to 1
dev:482022-12-21 09:54:01.873 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 14
dev:482022-12-21 09:54:01.871 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 14 with a size of 1 bytes to 5
dev:482022-12-21 09:54:01.868 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 13
dev:482022-12-21 09:54:01.866 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 13 with a size of 2 bytes to 170
dev:482022-12-21 09:54:01.856 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 12
dev:482022-12-21 09:54:01.855 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 12 with a size of 1 bytes to 15
dev:482022-12-21 09:54:01.851 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 11
dev:482022-12-21 09:54:01.849 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 11 with a size of 1 bytes to 0
dev:482022-12-21 09:54:01.846 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 10
dev:482022-12-21 09:54:01.844 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 10 with a size of 1 bytes to 0
dev:482022-12-21 09:54:01.840 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 9
dev:482022-12-21 09:54:01.838 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 9 with a size of 1 bytes to 0
dev:482022-12-21 09:54:01.835 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 8
dev:482022-12-21 09:54:01.833 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 8 with a size of 2 bytes to 0
dev:482022-12-21 09:54:01.828 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 7
dev:482022-12-21 09:54:01.826 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 7 with a size of 1 bytes to 0
dev:482022-12-21 09:54:01.822 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 6
dev:482022-12-21 09:54:01.820 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 6 with a size of 1 bytes to 99
dev:482022-12-21 09:54:01.816 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 5
dev:482022-12-21 09:54:01.814 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 5 with a size of 1 bytes to 1
dev:482022-12-21 09:54:01.810 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 4
dev:482022-12-21 09:54:01.808 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 4 with a size of 1 bytes to 101
dev:482022-12-21 09:54:01.804 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 3
dev:482022-12-21 09:54:01.803 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 3 with a size of 1 bytes to 101
dev:482022-12-21 09:54:01.798 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 2
dev:482022-12-21 09:54:01.798 PMinfoInovelli Dimmer Red Series LZW31-SN: Supported association groups: 4
dev:482022-12-21 09:54:01.797 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 2 with a size of 1 bytes to 101
dev:482022-12-21 09:54:01.795 PMdebugInovelli Dimmer Red Series LZW31-SN: AssociationGroupingsReport(supportedGroupings: 4)
dev:482022-12-21 09:54:01.783 PMinfoInovelli Dimmer Red Series LZW31-SN: Retreiving value of parameter 1
dev:482022-12-21 09:54:01.759 PMinfoInovelli Dimmer Red Series LZW31-SN: Setting parameter 1 with a size of 1 bytes to 3
dev:482022-12-21 09:54:01.750 PMinfoInovelli Dimmer Red Series LZW31-SN: Association info not known for group 5. Requesting info from device.
dev:482022-12-21 09:54:01.748 PMinfoInovelli Dimmer Red Series LZW31-SN: Association info not known for group 4. Requesting info from device.
dev:482022-12-21 09:54:01.747 PMinfoInovelli Dimmer Red Series LZW31-SN: Association info not known for group 3. Requesting info from device.
dev:482022-12-21 09:54:01.745 PMinfoInovelli Dimmer Red Series LZW31-SN: Association info not known for group 2. Requesting info from device.
dev:482022-12-21 09:54:01.734 PMinfoInovelli Dimmer Red Series LZW31-SN: Association info not known for group 1. Requesting info from device.
dev:482022-12-21 09:54:01.703 PMinfoInovelli Dimmer Red Series LZW31-SN: Getting supported association groups from device
dev:482022-12-21 09:54:01.668 PMinfoInovelli Dimmer Red Series LZW31-SN: componentRefresh(Inovelli Dimmer Red Series LZW31-SN (LED Color))
dev:482022-12-21 09:54:01.590 PMinfoInovelli Dimmer Red Series LZW31-SN: Switch Multilevel report received with value of off (0)
dev:482022-12-21 09:54:01.587 PMdebugInovelli Dimmer Red Series LZW31-SN: SwitchMultilevelReport(value: 0, targetValue: 0, duration: 0)
dev:482022-12-21 09:54:01.466 PMinfoInovelli Dimmer Red Series LZW31-SN: configure()
dev:482022-12-21 09:54:01.395 PMdebugrefresh()
dev:482022-12-21 09:54:01.390 PMinfoInovelli Dimmer Red Series LZW31-SN: installed()
Welcome aboard. First things first, I upgraded your account so you can share pictures.
Thank you!
I was wondering what you meant by "Dashboard". After adding the device, have you tested on the Device Details page that it works? Once we establish that the device works as expected, then we can tackle the Dashboard issue.
On/Off from the device page works.
Well, it depends on what "everything" is :slight_smile: Currently the integration allows Google Home to control switches, dimmers, thermostats, and bulbs that have been joined to your Hubitat Elevation hub
https://docs2.hubitat.com/en/apps/google-home
I followed that but have noticed when I check a device in the list and save, it doesn't show in Google Home and when i go back to the list in the hub, it its still unchecked.
Ok, will come back to that after fixing the Dashboard :slight_smile:
Hit the menu in the upper right corner...
And select the template you'd like (switch or dimmer).
Ok that is working now. Man I feel dumb. I just deleted the other tile that showed Inovelli. Not sure why it created two tiles.
Because it has two devices, one for the main dimmer and one for the LED notification:
That is very odd. I have many Inovelli Red Series authorized to use with Google and never had a problem. I would try to select the device again, then be sure to hit "Update" then "Done". Hitting "Done" is critical element to save the change, otherwise the changes are not saved if you just hit back on your browser, for example.
Thank you. I am going to start adding my other dimmers now and will give it a shot. Really appreciate the support.
Here is an example. I have 7 Sengled Mutli color can lights in the kitchen. No matter how many times i check the boxes, click update, click done, reconnect habitat in Google Home they do not appear. I go back to the Apps screen and they are unchecked again.
I did get the 5 Inovelli Red dimmers working eventually.
Here is one of the GH issues I am having right now. Two of the same bulbs setup exactly the same. One shows up in Google Home and one doesn't show no matter how many times I enable in the Hubitat Apps section.
This has happened with many other devices like 7 Sengled color can lights. 5 are setup using Generic Zigbee RGBW driver and 2 are using Advanced Zigbee RGBW bulb which the colors are off but is the only way they appear in Google Home. Many of these devices I have had to play around with the list of drivers until it shows in Google Home. The Sengled ones don't work for these bulbs. Is there something I'm missing?
I am trying to leave Smartthings because of Webcore but the excellent GH integration unfortunately might keep me there,
