I have an ON rule and an OFF rule for each of my 33 Inovelli Blue's configured in dimmer mode. To reduce maintenance, I wanted to consolidate to one rule per device that is triggered by either a top-paddle tap (ON) OR a lower-paddle tap (OFF), then apply rule statements depending on which paddle tap triggered the rule.
For IB's, a tap on the top-paddle registers as "button 1 pushed" and a tap on the bottom-paddle registers as "button 1 held" . The value of %value% for my ON rule is "1", and the value of %value% for my OFF rule is also "1", so that isn't a viable way to distinguish top vs. bottom paddle taps.
So the following example Rule works. An IB device can be either a switch or a button. A tap on the bottom paddle creates a switch state of OFF and makes %value% = "off", causing the IF clause to run. A tap on the top paddle ( %value% = "1") causes the ELSE clause to run.
In generating this Rule, I found no way to test %value% directly, hence the assignment to the local variable vState.
I do something similar with webcore and my homeseer dimmers/switches. I use the double tap on some of them to control other lighting zones and wanted to simplify.
I just convert the double-tapped button number to the target device’s target switch state. I can set dim level instead by multiplying that value by the target dim level.
In your case, that might be more challenging - with lower paddle being held. What event does the inovelli show when you actually hold the top paddle? Just curious.
The "button 1 held" response to a lower tap is due to Inovelli's button-mapping strategy.
For their Gen 3 switches, that mapping can be found here... This is a helpful resource to bookmark for (in particular) setting up Button Controller rules. For example, holding the top paddle (in on/off mode) is considered "button 6 pushed"
To be clear, for the Inovelli Blue units in the rule example above, neither paddle is actually held, but only tapped. The device responds with a code corresponding to “button 1 pushed” or “button 1 held”. See the table kindly posted by hydro311
Inovelli Blue -- how to distinguish multi-taps on bottom paddle vs. top paddle?
Further experimentation shows that Hubitat’s Rule Machine sets the internal %value% variable as follows for Invovelli Blue paddle taps (all values are strings):
Switch state commands
Dimmer turns ON = ON
Dimmer turns OFF = OFF
Button state commands
Tap Up on Light Paddle 1x = 1
Tap Up on Light Paddle 2x = 2
Tap Up on Light Paddle 3x = 3
Tap Down on Light Paddle 1x = 1
Tap Down on Light Paddle 2x = 2
Tap Down on Light Paddle 3x = 3
Notice the results for Up and Down taps – the same values for the same number of taps. For example, if the switch is ON and the Down paddle is tapped 2x times, %value% gets set to “2” – which cannot be distinguished from a 2x tap on the Up paddle.
So I can’t see how to distinguish multiple Up taps from multiple Down taps in Rule Machine for an Inovelli Blue.
NOTE: I know how to distinguish Inovelli Blue taps of all kinds when used as triggers, but I’m using multiple triggers on the same switch to run different conditions in a Rule. Accordingly, after a rule is triggered, I have a need to determine WHICH trigger ran the rule.
Is there a known way to distinguish multiple Up taps from multiple Down taps in Rule Machine for an Inovelli Blue switch/dimmer?
As noted above, Inovelli Blues give the same values for the same number for either Up or Down paddle taps. Accordingly, %value% cannot be used to distinguish an Up paddle double-tap from a Down paddle double-tap.
Instead, the “lastButton” attribute can be used to determine the number of taps. That attribute returns strings like “Tap ▼▼” (down paddle double tap) and “Tap ▲▲▲” (up paddle triple tap). Example test code:
