That is how I initiated pairing. I guess I missed the wash rinse repeat in the instructions. As I wrote, the previous driver works without drama.
I believe that it may have been a coincidence, but maybe not. I have seen that behavior on several driver versions but I didn't realize it until I saw your post with reference to the red flashing. I've been using the C-8 with the latest driver from HPM and have not seen the issue yet, but I will keep an eye out. The odds have been greatly reduced with fw 2.15, but there still is a possibility that something interrupts the key exchange. So the device will be on the network, but cannot be talked to because the security keys are not in place. It happens more frequently when there is another coordinator (sometimes not known by the user) and it interrupts the pairing process.
After pairing it would drop off with the 07 driver installed. With the 04 driver it continued as one would expect. I did this more than once to confirm. Right now I'm on the 04 without any issues. Maybe an issue with a repeater that is close to the hub.
This has happened to me several times - Zigbee2MQTT coordinator stuck in pairing mode. Power cycling the Z2M Zigbee stick fixed the Hubitat pairing problem for me.
