Hi
New to Hubitat. Just purchased a Inovell LZW31-SN. I have the driver from Inovelli installed and I am able to use the 'up' switch to activate the HSM 'away' works great . I even set the LED to RED. So now when I push the up button it sets my alarm to away and LED to red. Works perfect
My problem is I can't seem to get the switch to recognize the down button 'off'. No matter what I do I can't get it to see the down button push as an event. Weird thing is I can see it in the logs. But if I create a simple rule to chime when the up button is pushed it works - same rul for the down 'off' button and no chime.
I'm new to Hubitat and probably missing something obvious. I've looked in the setup of the switch and I don't see anything that would enable the other button (which I assume is button 2?)
Thanks in advance
