Influxdb2 and HE integration
@afshin.mashayekhi and @ronv42, I have gotten this to work using the 1.x compatibility API system.
You need to use the influx CLI to set it up.
First you create a bucket in the Influx web interface you want to use.
Then you have to create a DBRP mapping: influx v1 dbrp create | InfluxDB OSS 2.2 Documentation
If you have not setup the CLI with a saved config, you need to include the org and token. You get the bucket ID and operator token from the web admin.
influx v1 dbrp create \
  --bucket-id 12ab34cd56ef \
  --db example-db \
  --rp autogen \
  --default \
  --org example-org \
  --token operator_token
Then you need to create a v1 auth with write access: influx v1 auth create | InfluxDB OSS 2.2 Documentation
influx v1 auth create \
  --write-bucket 00xX00o0X001 \
  --username example-user \
  --org example-org \
Once that is done you should be able to fill in the blanks on the logger app and it will be able to connect. It is currently running for me:
