Inconsistent - Presence Sensors
Hub C-8 Pro running 2.4.3.137.
I'm using iPhones running iOS 18.6.2 (Hubitat application) and Locative running on a couple iPhones.
Both inconsistently reporting the correct status. Can be home and it reports not present or away which reports present. It seems the locative almost works better than the iPhones running Hubitat app.
Any thoughts how I can get the sensor to be more consistent? Right now, it is about 60/40, if it will work.
Sounds like the common denominator is your iPhone. I’d start here, regardless of model.
