In Search of A Lost Child (Zigbee)
The "Low Ram" devices are all Jasco switches, which are rock solid on the mesh.
The "High Ram" device that shows rather oddly in those logs is the HE itself -- as I understand it, the coordinator is always node 0000. I don't know why it's trying to discover itself, or route itself through itself. I also don't know why devices also seem to have a route loop like that from time to time in the neighbor table.
The hub is physically positioned on the top of a shelf on my desk, with nothing above it. None of my other zigbee devices (those Jasco switches, Osram's gardenspot outdoor LEDs, a pair of Sengled bulbs, a pile of plugs) ever fall out of contact -- just those LED strips. And the zigbee logs seem to show that they're not actually falling off the mesh, just changing addresses and then being ignored.
I feel like if those announcements the LED strips make when they get unplugged/replugged were caught, or there was a periodic poll of the mesh, we might be able to find them and re-associated them to the device.
I'm thinking that the Jasco switches, and this is a guess, are using the EFR32MG newer Zigbee chip or at least that's the only one I've ever seen report "low ram"
And my 2 HE C7 never reports itself as high ram, so don't know if you got a V 1.2 hub, all I know is from my perspective a bit odd, not necessarily bad tho.
tagging @support , maybe this is something they have seen before, especially as it seems all WAS well, then not
When you see a device 'routing through itself' this isn't a routing loop; it's just normally what you'll see in a route table entry (which only shows the first hop of any route) when the first hop to the destination is also the complete route. Meaning, the hub is sending a message to one of its neighbor routers-- the first and last hop are one and the same.
So that jogged my memory regarding the [null, 0000] via [null, 0000]... Whoops, I seem to have forgotten all about this when it came up some time ago: Seeing "In Discovery" in the routing table - #4 by Tony It's also normal....
High ram / Low ram concentrators are (AFAIK) features of the Zigbee stack (SiLabs refers to them as 'plug-ins') that can be enabled on some routers to make many-to-one routing more efficient. If a node is a high ram concentrator, it's telling other nodes that it has enough storage to hold a complete routing table and doesn't need a source route (back to the originating node) transmitted along with every message.
I really appreciate this in-depth information, @Tony ! I am learning a ton about the way Zigbee works with HE, and it’s very helpful in updating my approach to narrow down the root cause here.
I’d love to be able to actually see the device announcement raw message, so I could check the accuracy of my speculation that my wayward devices are getting their new addresses back to the HE successfully and it’s just not re-associating them. Is there a way to get the zigbee radio logs (not the device logs) to a debug level?
Here's thought out of left field, check on the web fcc.io and lookup the FCC-ID of these strips, could be they are ZLL? which are know to be problematic
I am about 95% sure these are ZHA 1.2 — back in the days before ZB3, folks who wanted to use these with Hue in the US had to reach out to Osram support to get them flashed to a ZLL firmware. They were sold ZHA in the Americas and ZLL in EMEA. I never did the flash, so they should be ZHA. I’ll check, though.
I know it’s been a minute, but I’ve confirmed these are all ZHA 1.2. I had another one go ā€œdarkā€ on me today. It showed activity in the zigbee logs, but HE just never went and re-associated the new address to the device. You can see some slow unplug/replugs in this screenshot, followed by Osram’s very annoying 2-off/5-on (x10) reset procedure, then me re-running device discovery, which finally found it and remapped it (ā€œIslandā€).
I know I’m like the only one with this issue, and it’s only with these specific LED strips, but I really do feel like it’s something with HE not picking it up at the new address. There were approx 20 opportunities in that screenshot to catch 145E and re-map, and I just can’t see a scenario where the data didn’t make it back to the HE for every single one of them. It’s less than 12 feet away.
So I know everyone has been waiting on the edge of their seats for the next chapter in this saga. I’ve got an update to share. After a fair amount of Googling, I learned that some zigbee devices just really don’t like low Zigbee channels. I took a look at my 2.4GHz spectrum and determined that I could move higher without much of an impact to congestion, so at the very end of December I did that when I was having these LED strips start to fall off the mesh on a daily basis, sometimes multiple per day.
This has effected a near-complete resolution of the issue — I’ve had only one go missing in the entire month since.
However, I have started to see Jasco switches start to exhibit the same symptoms, which they never have before. There are a couple key differences, though: manually actuating the switch immediately returns it to action, and taking no action results in them finding their way home again in no more than 24 hours (the LED strips wouldn’t ever recover — I left one in situ for a week and it never came back).
The physical switch action effecting it re-connecting it to HE makes sense; the activity prompts the switch to communicate its state change, and then HE seems to realize the switch isn’t where it thought it was. I don’t have enough log data to determine if the automatic recovery is a result of the switch figuring out it’s been lost and finding its way home, or the HE realizing there’s a problem and correcting it. Given that the Osram LED strips would go MIA forever, I suspect that the Jasco switches have slightly better health monitoring logic and are the initiators of the recovery, but I can’t prove it.
Ultimately, it would be nice if there was some built-in automatic recovery mechanism. The root cause seems to be a device changing its address and not getting that change recorded by the coordinator for one reason or another. An earlier post in this thread suggested that used to exist, but no longer does. Even if it were just an optional, opt-in setting, I’d love to have that available.
Is this a non plus z-wave switch? If so you need to install the built in z-wave poller. Or is it a zigbee switch?
Everything in discussion here is zigbee. I’m aware of the Wi-Fi and zigbee channel overlaps and have deployed accordingly.
Right just figured that I'd throw it up for you :slight_smile:
Maybe @mike.maxwell can chime in... I'd also note that not all zigbee devices like really high channels either. 20 is usually a good midpoint while keeping the ap's at under 11. I have one jasco zigbee outlet and when I first got it it gave me a lot of trouble. When I went the same route as you, with 11 or below settings and 20 for zigbee, lowering my signal strength from all the ap's, things stabilized immediately.
Bumping for visibility, as this bug is still unfixed. I’ve since observed it with Jasco switches as well. For those, at least manually actuating them will cause the HE to record its new address and connectivity will resume. However, since there is no way to manually actuate an LED strip, once they’ve changed their address and HE misses the memo, they’re de facto off the mesh until they’re factory reset and re-paired.
This doesn't seem to be an issue for any others so I'm not sure it's a "bug" vs something strange is going on on your system. I mean there are lots of people out there running all jasco/ge switches without issue. Based on the entire thread it seems that you have a device somewhere that isn't repeating properly. While I know that you've been through your mesh with a fine tooth comb, this almost sounds like the classic zll 1.2 bulb issue dropping devices.
Well, I’ve removed all those, so it’s not that. Please stop suggesting the problem is me.
I’ve literally reproduced the issue in the logs and provided them here. It’s a bug. If a device changes its address and HE doesn’t catch it when it happens, it will continue messaging to the old address indefinitely, even if the device announces itself again on the mesh when it’s unplugged/re-plugged. It’s ignored. That’s a bug. I know it’s a bug because other device-generated messages, such as an on/off state change, are not ignored — those correctly prompt HE to refresh its address table. HE responds correctly to one type of message event and not the other. A bug.
You can see HE doing the address refresh of a forgotten device from a state change event in the logs. You can see HE ignoring the other messages from a forgotten device in the logs. You can see the stale addresses in the zigbee device table. It’s very obvious what is happening and it’s not something I can fix by redoing my home or changing channels or using other bridges or anything else because it is a bug.
Tagging @mike.maxwell and @gopher.ny from the Hubitat team, as I haven't seen either of them chime in on this particular thread, yet. As they are the two SME's on Hubitat's Zigbee implementation, hopefully they can shed some light on what you've been experiencing on your Hubitat Hub since last November.
would the easiest way of seeing this issue be by firing up the zigbee logs and finding a log entry where the displayName is replaced with the devices (probably new 4 byte address)?
Yep! You need to cross-reference the zigbee logs and the HE event logs but it’s all there.
You can see it update the address when you run discovery after factorying a ā€œlostā€ device, or when a lost device sends a state change — zigbee logs show the device ID communicating, and event logs show HE recognizing it and updating the device address table. However, for devices that don’t have manual state changes, the only human intervention possible is to unplug and replug the device. When you do, the zigbee logs record the device (with no name) announcing its existence back on the mesh, but the event logs don’t show it updating the address, and the address table continues to show the previous—now vacant—address for the device.
Let me know if that makes sense?
I get it, now to just wait and see if it pops up again.
I had one device report this way in the zigbee logs, but didn't have enough internal logging to see the entire frame, i may have to packet capture to see the complete truth of the matter.
You’re welcome to monitor mine remotely if you would like. I go on walks after work, and my path usually has me wander in and out of a geofence I have set up with Alexa, which ends up toggling a Room Lights activator 6 times over the course of an hour. Enough devices are in that Room Lights app that one of them has usually gone MIA by the time I get back.
i forgot to ask, which model hub are you running?
