Image Refresh Broken?
Hub C8
Is the image tile with url and refresh for the dashboard broken?
I have a Reolink camera tile with update every second (pointing at a jpeg) using:
http://IP_Number/cgi-bin/api.cgi?cmd=Snap&channel=0&user=admin&password=QWERTY
It used to work fine. Now when I start the dashboard, I get 1 second of latest JPG, then flickers without content. I have tried changing to 10 seconds refresh, and image stays for 10 seconds, but as soon as it gets refreshed, I get nothing past the first image.
HTTP for the link works fine, showing consistent movement.
Is this my HUB or is there something not working right?
I'm on the latest firmware version. Again, this was not a problem a few weeks ago when I last tested.
I have the same problem. I have RLC-410 and RLC-510 cameras. I've only had the C8 hub, since I am new to Hubitat. I've been able to set up Amcrest cameras on dashboards and they refresh properly as long as I am on a Windows laptop. The image doesn't even appear in the dashboard tiles on iOS (neither iPhone nor tablet), just a box with a question mark.
The Reolink camera image displays properly on all of my platforms, but the refresh is broken, as you describe.
I might punt on using Hubitat dashboards and maybe get a Home Assistant hub to use in conjuction with the C8, but I would really like to keep it simple for now.
It seems there might be multiple bugs here - Amcrest refresh works, but not on mobile devices, Reolink displays correctly on multiple devices but doesn't refresh.
Is there a way to submit bug reports to Hubitat for this sort of thing?
Same on my end, RLC510A with C7. The image is loaded once Dashboard is opened, but never survive 1st refresh....
So confirmed with reolink, its a bug on 510A camera.. http://192.168.1.5/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=2343456sadfsadafda&time=123&user=USERNAME&password=PASSWORD works. The issue is once hubitat appends the timestamp to the end of the url only...
