Ikea TRADFRI Control Outlet driver issue?
I have a Ikea zigbee outlet that defaulted to using the new (?) HE driver. I'm using this primarily as a repeater but today I was playing around with the settings on the device page, I discovered that the "state" would not change (until I hit refresh) if I turned the device on/off from the page. I changed the driver to a Generic Zigbee Outlet and the state change happens immediately. Anyone else run into this?
If there is a Configure button, I would press that (I think there is such a button). I don't have these outlets on Hubitat anymore, but I know that the driver worked fine.
Yep - had tried that. But will switch back and see if that fixes it.
UPDATE: That did fix it! However, when I switched to the IKEA drivers, I got this entry in the log:
org.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: ikeaControlOutlet.runOptionTest() is applicable for argument types: () values: (runOptionTest)
Doesn't seem to happen after that intial time.
