Yeah, and sorry meant “Touchlink” when you select lights and then the + at the top right.
Hue is the way forward, I have had no issues with pairing the bulbs I have, although I haven't used any of the GU10's yet,
So you use this to pair Over the hue app and it has different results ?
iConnecthue is $7.99
Touchlink is Free
I would go for the touchlink then, I only used it to pair them and that was it. Could have sworn it was free TBH.
I tried many times to pair with the Hue app, and just didnt work for me. That could have been a firmware issue on the bulbs though, at that time.
Yeah see for me, I have 4 ikea bulbs here, 2 paired straight away, the other 2 never paired after multiple trieds and resets
I ended up getting the hub and updating. Ever since, its been in a cupbard lol.
yeah my hubs uptodate so I just assumed they didnt work.
I can try the touchlink one - see if it makes a difference.
Fingers crossed it works mate
was it called touchlink control ?
if so that hasn't been updated in 2yrs lol
Looking at that app, thats not it. I got the iconnecthue, I could have sworn that was free at the time.
If you have iOS you can use this I believe.
If Android, you can do it from a PC instead using Lamp Finder, link further down in the above.
There is also HUE lights which has touchlink inbuilt
Thats also in the link above
i'll give it a go on the GU10 I have at home, cheers lads
Can confirm that app with touch link does Not work to connect the GU10 I have here.
Link
Which isnt to say this other one wouldnt pair, as its been hit and miss which ones (model/colour) join and which dont
Its probably worth me buying this other one to test if it will join the hue hub, really.
Ones I have that Do Pair (to the hue hub)
but this one wont
Thats a downer. Have to say though I have had a couple of GU10s which wont pair, I put this down to the bulb being knackered more than anything else.
Have you updated the bulb with the tradfri hub to it's latest firmware?
I add them all to the ikea hub before trying them on the hue hub, yeah.
This doesn't answer my question...
The ikea hub auto updates the firmware when you add the bulb, so no I haven't updated the firmware as I add them to the hub, it updates it, then I remove the bulb and tried it on the hue hub.
Check. Didn't know it would automatically update. Since I have no tradfri hub myself.
