In the top section of the device page pressing it or turning it should return the respective number. 1 for one press, 2 for double click, 3 for three, and so on.
Before programming its behavior, make sure the button is communicating correctly.
I dont think I have a correct communication. I seems like no events is passed to Button1 , etc.
I have tried to pair the Symfoni button a couple of times,,, seems not to make any difference,, so what is wrong?????
Any suggestions, ideas is must apriciated.
I suggest you re-discover de device, without deleting the current one. It should be discovered as a current devive.
While you re-pair the device, maintain the current's device page open, and as soon as the discovery page detects it as a current device, press the Configure button.
For some devices it is recommended that you keep them "awake" by turning it, or pressing it, once each second, before you press "Configure".
To have it correctly linked and paired is the starting point. If the device page does not show any command from the device, then it is not correctly paired.
@lg.lindstrom It sounds like you simply missed the step of pressing the Configure button. If you do not do that after changing driver, the new driver parameters are not sent to the device. This only needs to be done once after changing the driver and clicking the "Save Device" button.
