Today I learned that my natural gas meter (Honeywell BK-G4MT) can be optionally equipped with an addon device to "read" the current meter value: Honeywell IN-Z61–IN-Z65.
Upon further reading, I learned that this device is just a reed switch that captures the moment a small magnet (that is attached to the rightmost counting wheel) is in its lowest position (the screen reads "zero" for this position).
So I had a brain fart: contact sensors can detect changes in magnetic fields! I attached an IKEA Parasoll contact sensor, and, lo and behold, it really works!
Now I just need to adjust the Parasoll driver to act as a bean counter!
Oh wow, very interesting. I'd like to see how this hack materializes?
Just checked local ikea inventory and then went outside to look at my gas meter. Not a honeywell
but it did make me think: If you move this project forward there may be grateful US Hubitaters whose gas meters measure in cubic feet
Gas charges here are also broken down into flat fees, distribution fees / unit and fees for the gas unit itself. There may also be tiered pricing depending on the number of units used. You could really create a great tool to help people avoid nasty bill suprises - or at least the suprise bit! Good luck with the project - very neat!
I wonder if a utility person stopping by would come to the opinion that meter theft was afoot?
Small update: I created the modified driver here: IKEA Parasoll Pulse Meter (E2013).
I have 2 problems:
- The index in Hubitat lags behind the real value, although I see constant events coming from the device to Hubitat. This could be either because the sensor misses some magnetic pulses (there is a 1 cm gap between the IKEA device and the magnet), or because of the very bad Zigbee signal I get from the device (LQI = 40/255). I cannot add a repeater device closer to the gas meter as that is public space, so I am looking for a repeater with a bigass antenna to compensate
- The theft issue that @velvetfoot raised is something I should indeed be worried about. I wrote an email to the gas distribution company to ask if it is possible for them to install the Honeywell IN-Z61 pulse detector (that I will probably wire to a Badring Water Leak detector instead).
One thing at a time, right now I'm focusing on getting the gas meter index value to Hubitat. Pricing stuff can be added alter, either in the driver code, or in a separate app. Thanks for the idea!
Yes, diving straight into the gas meter rabbit hole, and I don't even have that meter! LoL
Good luck with the project though
I've never given those door sensors a moments thought, but I'm starting to see niche use cases!
Inside those sensors is an actual mechanical reed switch. You most likely need a analog hall effect sensor. A hall effect will have a faster response time. You might be hitting the mechanical limit of that Reed switch depending on the cycle time. You might also have a minimum cycle time that the sensor can see as in it has a cool down period.
Might not be applicable where you are at, but I read my gas and water meter with a SDR stick and RTLAMR. Half the battle is figuring out which ones are yours. But they broadcast a radio signal every so often that you can pick up and decode.
Same. It reads the wireless transmission from the meter and brings it into Home Assistant, which is then brought into Hubitat. Works great!
Looks like the Parasoll sensor is solid-state.
I have one and swear I could hear it click.
Hmm, maybe your battery is moving a bit when you put the magnet next to the case?
