I tried this and it finds my device and shows it but it doesn't respond to on/off commands
Also would like to see support for iHome, isp6x outlets and iss50 multi-sensor.
Doesn't using IFTTT completely and totally defeat the purpose and huge benefit of having LOCAL home control/automation??? The reason I chose Hubitat was to get AWAY from cloud dependency. So I too would appreciate it very much if Hubitat could talk directly to my iHome devices.
Only local devices can be local. So if you want to sit and wait for someone to come up with a local driver for a really unpopular device, of course that's an option. You will be waiting a very long time I suspect.
Otherwise, if you use a cloud connector like IFTTT or Google Assistant Relay, you can start using and enjoying your cloud connected devices with Hubitat today. That is the entire reason for their existence. But since you see the great benefit in going local, then a Zigbee or Z-Wave device is a more appropriate choice.
I appreciate the info, truly. I was just throwing in another person wishing for support of the device that I already own and would like to continue using. Obviously if I had a bigger wallet I could just buy a bunch of stuff already specifically-supported by Hubitat. The current quest is to use my currently owned hardware with Hubitat, so I ended up in this thread, where multiple people were showing that they too wished for local support of this local device on our local Hubitat hub.
Just skimming through the thread, it's maybe 12 people over a two year period. That's just not enough to make the limited development resources at a small company like Hubitat available for a fairly complicated task. Especially if there's no local API available. From experience, devices like this are almost always going to come from a community effort by either someone that knows how to develop drivers and just happens to own one (and feels like putting in the large effort), or they're very popular and extremely useful and reliable devices, so the demand is very high.
iHome has been around a long time, but I have always noticed them on sale and typically still sitting on the shelf while everything else around them was gone. They just don't seem to have caught on very well. I'm not certain a plug that just turns on/off and doesn't offer anything else unique is going to catch much attention. There are just too many that do the same. There's a new Zigbee outlet from Sonoff that will work with the Generic Zigbee Switch driver on Hubitat. It's $17.99 on Amazon or $12.99 direct from Itead. If you don't care about the size, there's the IKEA Trådfri outlet for just $10.
However, if your iHome Outlet is iSP6X and you are an iOS user and own an Apple TV 4 or later, then you can setup Homebridge and control the outlet locally via HomeKit. Easiest way to setup Homebridge is Hoobs. Then you create a virtual switch in HE and expose that to HomeKit via Homebridge. In the Apple Home app, you create a HomeKit Automation so when the virtual switch turns on, the iHome outlet turns on, and a second automation so that when the Hubitat virtual switch turns off, the iHome outlet turns off with it. Most of the sensors in my home are Xiaomi Zigbee sensors that run on Homebridge via a HomeKit connected Xiaom Aqara gateway and HomeKit automations. Works perfectly and is all local. I also have two iDevices products that are only Alexa, Google or HomeKit compatible, so a very similar situation to the iHome outlet. They are connected via HomeKit/Homebridge and that works great for an all local control of them.
This worked perfectly. THANKS!!!
Hi,
I know this is an old post but I just converted to Hubitat from Wink and was trying your iHome json app for Hubitat to try and pull in my two (yes just two) iHome all plugs. I imported your app and driver and I am able to login fine but when you pull on the dropdown menu for devices it crashes with:
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: Cannot get property 'data' on null object
I had the live Hubitat log running at the time and even thought the UI errrored, it looks like the app and drivers partially worked because I see clearly in the logs that it pulled over the inventory, but apparently could not parse/display it:
customFields:[current_app_version:2.4.2 (249), current_os:iOS, current_os_version:14.5.0, initial_setup_app_version:2.0 (113), initial_setup_os:iOS, initial_setup_os_version:9.3.3, room_name:Office, service_type:heater], tags:[fw_updated, Active, SRA], updatedAt:1612960310446, name:Office Heater, product:UCfXBRHnse5Rpw7PySPYNq7b, properties:[actual_fw_version:0.9.17, appfwversion:0.9.17, auth_fail:0, currentpowerstate1:1, dhcp_fail:0, epoch:158, factoryreset:0, numoutlets:1, nw_not_found:31, outletinuse1:1, schedule:[], schedule_status:active, schedule_version:100, targetpowerstate1:1, timezone:America/New_York, ~connected:true], identifiers:[firmware_version:0.9.17, owner:Ug89yEUArSwwUcx5BQRUCg5n, serial_num:7130495641]], [id:UDtRdwU5P7mayeXegEXEannb, createdAt:1458581563254, customFields:[current_app_version:2.4.2 (249), current_os:iOS, current_os_version:14.5.0, initial_setup_app_version:2.0 (113), initial_setup_os:iOS, initial_setup_os_version:9.3.3, room_name:Office, service_type:other], tags:[fw_updated, Active, SRA], updatedAt:1612960310663, name:Office Light, product:UCfXBRHnse5Rpw7PySPYNq7b, properties:[actual_fw_version:0.9.17, appfwversion:0.9.17, auth_fail:0, currentpowerstate1:0, dhcp_fail:0, epoch:96, factoryreset:0, numoutlets:1, nw_not_found:32, outletinuse1:1, schedule:[], schedule_status:active, schedule_version:100, targetpowerstate1:0, timezone:America/New_York, ~connected:true]
Just wanted to know your take on that and if you have any suggestions for a fix I might be able to try.
Thanks for all your support to the commmunity!
Unfortunately I've moved away from Hubitat and probably won't get back to this integration.
Easiest way might be to set them up in Alexa and then add a couple of virtual switch/contact devices in HE to control them with by creating an on and off routine in Alexa for each.
Hopefully I can post this here. But I use the iHome isp5 and isp8 plugs and found the following hubitat driver and app on Github here
and they work great. I use them in rules and scenes and with little issue (except occasionally the cloud disconnects but seems to be normal with iHome)
yes they are still connected to the cloud, but the app logs you in and creates the devices (seems to be a few different devices but I only have the plugs) and the remotes still work so perfect for Christmas tree and lighting this time of year
So they are not fully local but have all the local control I need..
