Thank you for that suggestion, I’ll give it a try.
It will be interesting to see how multi-sensor devices are implemented in Alexa.
I’ve found that I can play around with different skills to get different capabilities from the same cloud-connected device into Alexa. For example, ecobee sensors ... the ecobee skill exposes it as a temperature sensor, while the Hubitat skill exposes the same device as a motion sensor.
