IFTTT in 2 hubs
I have IFTTT setup on 2 hubs. I would like each hub to be able to call my phone using IFTTT/VOIP. When I connect to Hubitat from the IFTTT website, it asks me if I want to use Hub-1 or Hub-2. I can't select both. So I thought I would be tricky and create a 2nd IFTTT account and specify Hub-2 when I connected to the Hubitat service. The only problem is the IFTTT app on my phone only supports one IFTTT account, so I can only receive a call from one of the hubs.
Has anyone done this? Is there a way to get IFTTT to see devices from both hubs?
The way I've worked around this is to use a MakerAPI endpoint (or you could use a rule with a cloud endpoint trigger) for one hub to relay the request for a call to the other hub, which is connected to IFTTT.
That is a great idea, thank you
