I'm trying to integrate my Nexx Garage door opener with Hubitat by using IFTTT to send open/close commands through Nexx but have an issue with trying to sync Manual state changes via physical switch.
Setup is like this:
"IF" Hubitat Virtual Garage Door Controller OPEN/CLOSE "THEN" IFTTT tells Nexx to OPEN/CLOSE.
The problem is when I manually open the door. I can see this via a Z-wave contact sensor, which I would want to update the state of my Hubitat Virtual Garage Door controller to Open/Close but I wouldn't want it to trigger the IFTTT event which would tell Nexx to do the same thing.
I was hoping to use a Button or something to send commands instead of monitoring open/closed state but it doesn't look like there is an applet for Hubitat buttons in IFTTT. I read a similar issue someone was suggesting to have a sync event but that's basically what this is doing to begin with via the virtual garage controller. The only other thing I could think of is there a way to silently update my virtual garage controller without triggering the state change to IFTTT in certain cases?
Anyone have any suggestions how I can get this to work without duplicate commands being sent?
Thanks!
