One of the beam sensors mounted on one wall, the other is on other side of where my car sits. Some weekend when I have time I'll work on prettying up the power wires for these
Just to test things out for a few days I'm just passing the state change to Telegram with pics of my car/garage Thanks to all for the help and conversation!
@morningz, Does each side of the beam sensor have a aeotec open closed sensors? I use the Ecolink open/closed sensor do you think it will do the same thing?
I know absolutely zero about the sensor you have so i cannot say for sure, but if it takes "the beam sensors close a circuit to kick off an action", than it should
I use this beam sensor in my garage too. Works like a charm.
Does anyone know if two pairs could be used in the same vicinity or would the signals interfere somehow. I ask because I’d like to monitor each spot in a 2-car garage independently for presence of a car. TIA….
Can use an ultrasonic distance measurement, too. I have two of those made with esp8266 that I use both as a parking distance/position tool (there is an LED readout) and as an input to home automation for car presence detection.
I'd love to try your approach for the simple reason that ultrasonic distance can be physically installed on the garage ceiling, full stop. When using the photoelectric beams, by contrast, there aren't great answers for device placement, particularly for a multi-car garage, as in our home, without partitions between the car "spaces". So my tentative approach is to put transmitter unit on the floor at the back of the garage (up against the interior curb) and the receiver on the ceiling toward the front of the garage. I can't put the transmitter on the back wall, because we have storage between the wall and the parking spots. My layout will work, but having a sensor on the floor -- yuck -- asking for trouble.
But I'm not a esp8266 guy and don't have development skills, so I thought ultrasonic might be over my pay grade. You think that's wrong?
It may/may not be something you want to tackle... Takes a bit of work if you have never done a single board computer like an arduino or esp8266.
For this project I believe I started with this link (or one basically just like it - been a while so probably wasn't this exact link). This will give you a general/example/overview on what it takes from a coding perspective.
Then I added the code for an LED display to it (you wouldn't need that).
Then I added the code to send the data to MQTT for use in Hubitat & node-red
I haven't thought about this in nearly a year. But was just browsing through the Hubitat community looking for unread topics...
What I did, which works nearly flawlessly, is to use a pressure mat and the Aeotec Door Sensor (series 7) which includes raw contact inputs to trigger open/close detection. Then wire the pressure mat into those connections and TADA! Now when either of the two cars drives over their perspective mat it will trigger a close event to HE. Then I take that 'sensor' input and wash it through a webcore piston that toggles a virtual switch. The virtual switch is named for each car (ex: Vehicle1, Vehicle2).
The practical effect is when the Vehicle is unparked, have Vehicle1 virtual switch OFF. Then when the car drives over the pressure mat the webcore piston will toggle Vehicle1 to ON. I did it this way because these pressure mats are not designed to withstand a constant pressure of more than 60lbs, however, I have found in practice that driving over them for a minimal duration (1-2 sec) doesn't 'appear' to damage the material that's is used to close connection.
The rest is up to the user. I have a rather elaborate series or Webcore pistons that controls nearly every aspect of garage automation. Obviously at the heart is this function for determining Vehicle Presence. The next part is tagging the drivers mobile device presence to the vehicle that just departed the garage to pair up vehicle/driver info that allow the mobile device to now be a vehicle tracker. There is much more, but getting off topic now....
The Aeotec sensor is a bit high priced, but the battery last forever! It's also the only reliable one I have found that allows for direct wired contacts as an input.
Hope someone finds this information useful. I've had this system in operation for about a year and it's never failed to determine when a Vehicle is departing/arriving.
