Hi guys,i made a simple rule,but for 3 days has not work,,,can you take a look if something is bad or i miss something? thanks
Edit: Sorry i forgot mention what happen,the rule turn on the light but does not turn it off
Can you explain what, if anything, you are seeing from this rule? Is the "on" not working, or the "off", or both?
A few things you can check:
HI¡¡ Sorry i forgot mention it,the light turn on correctly,but is not turning off
Hm, I am not sure how the rule "interprets" "day", because the off command relative to the on command is day+1. What happens if you split this into 2 rules, one for on, one for off
@mlatz Along those lines, I was wondering if an additional wait might help. Something like:
When Time of Day is 20 minutes before sunrise ...
Turn on [switch]
Wait until Time of Day is 1:00 AM, then ...
Wait until Time of Day is 30 minutes after sunrise , then ...
Turn off [switch]
Hallo, the rule now is not the same as initially .... only "sunrise". If I assume, that this is an unwanted error and you would modify the initial rule I think this will not work.
My feeling is: First it waits for sunset of THE day -> action
Then it again gets "day" and waits for sunrise, but THIS day there will be no sunrise anymore.
Sorry for the Outdated and late news
I think my hub just get a bug or something,a few days after this post,i reset the Hubitat (The most common problem solver in the electronic world,and i forgot it) and after that,my basic rule work perfect,as i want it,as spected
Thanks to everyone
