My Russound AV receiver accepts text commands over IP. The manual says the Russound IO (RIO)...
"The RIO Command Set is available as ASCII text via IP (using port 9621)"
Using PuTTY, raw mode, 192.168.0.39:9621 I can enter VERSION and get...
S VERSION="01.08.00"
What would be the equivalent Curl command? I have tried several but only get errors.
I could be wrong, but I would think the AV receiver is not using the http protocol on that port, if you are issuing the command via putty, so I would not expect a http request via curl to work. Hopefully someone more knowledgeable than me can confirm this..
If you are wanting to control this via HE, then you will likely need a driver to issue a lan command or whatever the right term is.
I am using a telnet connection for control right now, thanks to some great help from @bptworld. Just looking at different options for control. How does PuTTY manage the connection?
PuTTY is usually Telnet or SSH
But with PuTTY, I specifically choose a raw connection and not telnet or SSH. Does that make a difference?
IIRC raw is telnet
"Introduction
This document provides a description of a new protocol intended to ease integration of 3rd party
devices and software with Russound C-Series and E-Series systems. We refer to this new feature as
Russound I/O, or RIO.
RIO is a new text-based command set that improves upon our 3rd Party Integration Support, making
it easier to develop UI devices and applications that require Russound system integration and control.
Here is a summary of the services provided by this new command set:
β’ Serves as a superset of the existing RNet protocol capability
β’ Full 2-way communication capability
β’ The RIO Command Set is available as ASCII text via IP (using port 9621) and RS232
interfaces. Up to 8 simultaneous IP connections is supported for C-Series and E-Series
systems."
So maybe this does not mean http over IP...
I may sound like I understand communication protocols and such......I definitely do not.
Based on that, I'd try the Hubitat rawSocket interface: Raw Socket Interface | Hubitat Documentation
I also am interested in controlling my Russound devices over Rio. There is a driver in home assistant that is being worked on but it is being worked on very slowly. I specifically want control of my Russound MBX streamers. I currently control them through an old instance of Homeseer that I leave running just for this purpose.
Did you make any progress on this as I plan to dive in and figure it out? Thanks.
Doesnβt sound like an http connection at all.
Does the receiver have a web server you can browse to?
Curl is a command line tool for getting or sending data with http.
But many communication protocols are also traveling over your IP network. SSH, Telnet, DNS, NTP, mDNS, RDP, VNC etc.
@mike.maxwell wrote an awesome driver for the Russound receivers. Russound Zone Controller Virtual Device is included in the 2.4.0 release. I use it daily. Not sure about the MBX devices. Maybe he can give us some insight.
Sounds interesting. I would like to learn more. Thanks.
I took a stab at writing a driver with my friend Claude ai and have it up and running. If anyone has need of a Russound MBX driver then let me know and I will post it.
