There have been quite a few Vera converts over the years, I am not one of them. I came from a different hub Wink, and Hubitat is a million times better. I am very happy with it for whatever it is worth. Most reports from former Vera users seem positive about the switch. A couple examples:
Aloha former MiCasaVerde & Vera users. Here are a couple pointers for those considering of making the transition to Hubitat.
The biggest question on your mind is probably, should I make the switch? My answer is, yes. While I am slightly technical, I am definitely not a programmer, never messed with Lump code or any other code for that matter or used more than a single hub with a dozen or so various switches. But lately, Vera has become so unreliable, especially with its Alexa integrations which…
Having migrated my first home easily/quickly to Hubitat in January, I just got around to migrating my second home (much larger network than my first home) from Vera Plus to Hubitat and, all things considered, it went perfectly. It took almost a full day, but all of my stumbles and delays were with my devices, not with Hubitat (for example, my Somfy shades didn't offer a way to factory reset only the Z-wave - the factory resets also wiped the shade set points. After learning this the hard way o…
