I just discovered my zigbee ADT Water Leak Detectors do not have update application/software build. HOW DO I DO THIS WITHOUT REMOVING AND INSTALLING AGAIN?
I just added another ADT Water Leak Detector to my C7 hub running Platform Version
2.4.0.151.
I also just found out my other, already installed for over a year and identical devices are not working.
They have no visable errors I can find and the only difference I see is the "Application" and "Software Build" under device data on my newly installed vs the older ones have a different version.
Can I update these older one without removing and installing again?
Have you tried new batteries?
I'd be surprised if Hubitat had a firmware update in-hand for these, but you could check by switching the device driver (Type) to "Device" and attempting the zigbee firmware upadte button from there - if Hubitat has one available, it'll load. If not, no harm trying.
