I give up
Those are the Big Bullet Points... but it's glossing over the fact that both ZWave and Zigbee chips are new/upgraded versions and that the antennas for them are external. Yes, together that results in greater range, if the antennas are properly oriented. :slight_smile:
Ok, thanks
So l take it, not really worth upgrading unless you are currently having range issues and/or require built-in WiFi or l am missing something here?
Those are the current benefits. Other possible future updates are:
  1. Matter (very likely why they switched to C8 in the first place)
  2. Z-wave Long Range (now theoretically possible and somewhat likely, staff will probably tell us more once the LR devices start being produced so they can be tested)
  3. Zigbee Green Power (unknown, but should be possible now?)
I have used the c7 with Aqara mesh to the C8 and so far so good. I couldn't get them on the C8 and they worked fine with the C7 I hate to trash them they are pretty good devices and inexpensive too. I suggest give it a go!
.117 firmware is out with a fix for the HUE motion issues to try out.
