I can't include, exclude, or factory reset a Zooz Zen15 800LR to my C-7 Version 2.4.2.160. Would a C-8 HUB with 2.3.9 work with Z-Wave Long Range (ZWLR) Inclusion?
I am following the instructions in the " How To Remove Ghost Devices using hub tools or a UZB Stick" Support. I am down to the section "Using the HE hub's built in ghost removal tool". I am trying to run ZWaveJS on my C-7 Hub.
C8 and earlier hubs: Use the endpoints below. Type them into your browser address bar and press enter. You MUST REBOOT THE HUB afterwards for it to take effect. You can find your hub's IP address on Settings > Hub Details.
Enable ZWaveJS:
  • hubIPaddress/hub/zwave2/enable
Disable ZWaveJS and return to ZipGateway:
  • hubIPaddress/hub/zwave2/disable
  • OR use the button mentioned above to return to ZIP on any hub model
I have entered my ip address (hubIPaddress/hub/zwave2/enable) into my Edge Browser and hit enter. I then rebooted the C-7 Hub. How do I tell if this worked? I don't know how to tell whether I am running ZWaveJS, ZipGateway, or something else entirely.
Here is the device node:
0x0012 (18) PER: 0, RTT Avg: ms, LWR RSSI: N/A
Neighbors: 15, Route Changes: 0 Pending
SPECIFIC_TYPE POWER_SWITCH_MULTILEVEL
None
There are two buttons REFRESH and REMOVE
I followed the instructions to Remove Ghosts: REFRESH then REMOVE. There are now Refresh and Remove buttons and the status is PENDING.
Here are the relevant logs (latest one on the top)
sys:12025-09-23 10:10:46.584 AM
info
Failed node 12 remove status: 0 SDK failure node is no longer in failed node list
sys:12025-09-23 10:09:53.591 AM
info
Failed node 12 remove status: no reply
dev:6392025-09-23 10:09:50.180 AM
debug
parse:zw device: BD, command: 8003, payload: 14 , isMulticast: false
dev:5972025-09-23 10:09:50.069 AM
error
java.lang.NullPointerException: Cannot get property 'displayName' on null object on line 246 (method batteryHandler)
app:8032025-09-23 10:09:49.978 AM
warn
Z-Wave Network responded with Busy message.
sys:12025-09-23 10:09:43.587 AM
info
dev:6392025-09-23 10:09:43.233 AM
debug
dev:6392025-09-23 10:09:36.751 AM
debug
sys:12025-09-23 10:09:33.594 AM
warn
The Node is currently in PENDING. Can I move onto the next blank Node or is it better to wait for each Node to clear?
Thanks for the support!
Tom
