I have a supplemental, low-wattage heater in the office. Its onboard rheostat stays set to max. I have a temperature sensor (Office Sensor) in the room and the heat is plugged into a Zigbee outlet (Office Outlet).
On weekdays between 5 am and 7 pm, I want to turn the heater on if the temperature is below 70F and off any time it reaches 75F.
I really feel dumb, but in my defense, my HE has been rock-solid and I ain't had to even look at a dashboard much less hang any code since rm2.5.
I have done this 2 different ways, one entirely in RM. One using a virtual thermostat. Which one do you want?
Doing this from memory
trigger:
Time becomes 5AM or
Time becomes 7pm or
Temperature of Office sensor <70
Temperature of Office sensor >75
Actions:
If not time between 5AM and 7pm then
Heater off
exit rule
end if
if temperature >75 then
Heater on
else if temperature <70 then
Heater off
end if
Now I also add an extra rule that creates a variable that is true if the temp sensor has updated in the last hour, and use that variable to turn off the heater, I can add that code as well
What he said, except the opposite on the temperature actions. OFF at 75, and ON at 70.
oops, that is why we don't do things from memory!!!
Thanks! I can see one mistake I was making already. I'll give it a go.
