Humidty Temperature Device with display Telink TLSR82xx
I bought this humidity device from Ali thinking it was the same as one I bought before but it seems like it is not. I was able to pair it fine but none of the drivers I could find will make it work. I tried several custom drivers and the built in ones too. Any ideas what to try ? Here is what it says as it's identity:
Application 00
Endpoint Id 01
In Clusters
0000,0003,0020,0402,0405,0001
Manufacturer TELINK
Model TLSR82xx
Out Clusters 0019
Software Build null
After changing the driver to one that supports temperature and humidity sensors, obligatory pair the device once again to your hub (without deleting it).
Simply changing drivers and clicking on the Configure button may not work for sleepy battery-powered Zigbee devices.
Thanks for this, it made a difference. I went thru every driver I could find and then tried the "Sonoff Zigbee Temperature/Humidity Sensor Driver" and now it seems to be working. Probably took more time than it was worth but it's going now. Thanks again!
