Humidity temperature device options
I currently use Konke temperature humidity device on my ZigBee device and it works perfectly (I think it's Konke Temp-Humidity Sensor KPFT Zigbee compatibility).
Yesterday, it just died completely, which is sad. I am in Canada. Any recommendations on what ZigBee temperature/humidity sensor worked well worth a recommendation? I am fine for longer shipping delay and avoiding too expensive devices.
If you’re very happy with it, have you considered getting the same sensor as a replacement?
If you want something with a display, I've been using these for over a year and am very happy with them. Sonoff SNZB-02D
yeah, I would go back and buy the same as a fall back, just checking first though, if anything has surfaced recently which people are finding good.
Thanks. Interesting, though mine well get tucked on top of door frame, out of sight to trigger washroom fans, so a display is not high on my list.
I have a few of these and they've been rock solid. I've only been running them for about 7 months but battery is still showing 100%, for what that's worth. You can pick them up on amazon but if your willing to do Aliexpress you can get them on sale for about $4 a piece right now.
What driver are you using for these? Hubitat defaulted to the Generic Zigbee Temperature/Humidity Sensor. I tried using the Sonoff Markus driver for the SNZB-02 and it seems to work to get some additional attributes like presence, but I can't get it to work with this one for healthStatus [RELEASE] Tuya Temperature Humidity Illuminance LCD Display with a Clock (w/ healthStatus)
That's the wrong driver. I'm using the stock Sonoff Zigbee Temperature/Humidity Sensor.
Curious, what driver you're using with the SNZB-02P (Puck) that actually reports battery life? can't seem to get the battery report to work with these. Using both the generic as well as the "Sonoff SNZB-02P Driver" from the community.
The driver from kkossev works with the puck version of this sensor and reports battery life.
