I see Mike added the driver to HE, but I am only getting a single event out of the device, button 1 pushed. Is this correct?
Here's the info from toolbox driver:
Summary
dev:20712022-12-19 03:37:43.406 PMinfoCOPY AND PASTE THIS ROW TO THE DEVELOPER: fingerprint model:"RDM001", manufacturer:"Signify Netherlands B.V.", profileId:"0104", endpointId:"01", inClusters:"0000,0001,0003,FC00", outClusters:"0003,0004,0006,0008,0019", application:"09"
dev:20712022-12-19 03:37:43.402 PMtraceApplication: 09
dev:20712022-12-19 03:37:43.399 PMtraceModel: RDM001
dev:20712022-12-19 03:37:43.396 PMtraceManufacturer: Signify Netherlands B.V.
dev:20712022-12-19 03:37:43.392 PMdebugGetting info for Zigbee device...
dev:20712022-12-19 03:37:43.336 PMtraceSimple Descriptor Information Received - description:catchall: 0000 8004 00 00 0040 00 841B 00 00 0000 00 00 61001B841A0104012008010400000100030000FC0503000400060008001900 | parseMap:[raw:catchall: 0000 8004 00 00 0040 00 841B 00 00 0000 00 00 61001B841A0104012008010400000100030000FC0503000400060008001900, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:841B, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[61, 00, 1B, 84, 1A, 01, 04, 01, 20, 08, 01, 04, 00, 00, 01, 00, 03, 00, 00, FC, 05, 03, 00, 04, 00, 06, 00, 08, 00, 19, 00]]
dev:20712022-12-19 03:37:43.102 PMinfoINCOMPLETE - DO NOT SUBMIT THIS - TRY AGAIN: fingerprint model:"RDM001", manufacturer:"Signify Netherlands B.V.", profileId:"0104", endpointId:"01", inClusters:"null", outClusters:"null", application:"09"
dev:20712022-12-19 03:37:43.089 PMwarnOne or multiple pieces of data needed for the fingerprint is missing, requesting it from the device. If it is a sleepy device you may have to wake it up and run this command again. Run this command again to get the new fingerprint.
dev:20712022-12-19 03:37:43.086 PMtraceApplication: 09
dev:20712022-12-19 03:37:43.083 PMtraceModel: RDM001
dev:20712022-12-19 03:37:43.080 PMtraceManufacturer: Signify Netherlands B.V.
dev:20712022-12-19 03:37:43.076 PMdebugGetting info for Zigbee device...
Here is the join data:
I thought this device supported changing the switch type between momentary and toggle.
Here's the only event produced: " ||||||||||
|pushed|1||__Phillips Wall Switch button 1 was pushed [digital]|"
