Groups mostly, they worked before. I’ll try individual lights and see how that goes.
I dug into this and am embarrassed to say that the image I restored back to had the rule disabling switch on.
To sum up, a ton of issues on the 1.1.0.122 with hue lights. rolled back to 1.1.0.120 and RM is working fine.
This problem cropped up on me today. I had taken everything in my data closet out and re-mounted and cleaned.
Turned out, the Hue Bridge hadn't been assigned a static address. Although I cannot confirm that the IP changed, I suspect it did. I made it static and removed Hue Integration from Hubitat and added it back. Everything started working again.
Now to add back the bulbs to my rules...
