Hubitat lost connection to Hue Bridge, failed discovery several times (tried rebooting both hubitat and hue bridge and have verified both are up to date). Then tried uninstalling and reinstalling the app in hubitat but still failing discovery. Both devices are plugged directly into a TP-Link Archer router and have DHCP assigned addresses in the same subnet. Any ideas?
I tested this very recently and it was working for me, and this part of the integration app hasn't changed in several years. So, it's at least not totally broken, but I don't know why it's not working for you. Maybe reboot your Hue Bridge to see if that helps? I'm assuming you can connect to it (locally) from the Hue app or other means?
Discovery in the app can take a minute or two, and the page should refresh periodically and show you what it found, but another thing you can try if it's been a couple minutes and nothing shows up is to refresh the page in the browser yourself and see if it changes.
Not sure what was happening but I logged into Hubitat from a different device and it reconnected with no issues, thank you!
