the limit is in Hue then...
I was deleting in Hubitat. I have not reached a limit in Hue. The problem again is Hue groups being created not showing in the drop down for selection of use. Hubitat sees it as you can see in the screen shots above. They don't populate to the right portion for me to select it for use.
can you paste the text content of the groups that you took a screen shot of above?, DM this if you like.
I'm not sure if it's of use as the 2 groups that won't working/updating properly are now added after much back and fourth of deleting and name changing etc. Can you just right click and open in new window to view it larger?
But here's the current status.
{22={sensors=[], name=Floor Lamp, recycle=false, action={xy=[0.4573, 0.4100], ct=366, alert=select, sat=140, effect=none, bri=254, hue=8417, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Living room, lights=[12, 41]}, 23={sensors=[], name=Master Closet LG, recycle=false, action={ct=286, alert=select, bri=254, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Living room, lights=[57]}, 13={sensors=[], name=Gin Office LG, recycle=false, action={ct=313, alert=select, bri=254, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Lounge, lights=[46, 47, 48, 49, 36, 37, 38, 39]}, 24={sensors=[], name=Stairway LG, recycle=false, action={ct=370, alert=select, bri=13, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Living room, lights=[16, 31, 14, 15, 7, 8, 10, 11]}, 14={sensors=[], name=Dining Room, recycle=false, action={ct=230, alert=select, bri=254, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Living room, lights=[42, 3, 4]}, 16={sensors=[], name=South Bedroom LG, recycle=false, action={ct=286, alert=select, bri=254, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Living room, lights=[20, 21, 27, 29]}, 18={sensors=[], name=SBR Nook LG, recycle=false, action={ct=222, alert=select, bri=254, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Living room, lights=[23]}, 19={sensors=[], name=Mila Closet LG, recycle=false, action={ct=294, alert=none, bri=254, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Living room, lights=[18, 25]}, 1={sensors=[], name=Mila Bedroom LG, recycle=false, action={ct=370, alert=select, bri=10, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Kids bedroom, lights=[19, 30, 28, 26]}, 2={sensors=[], name=Master Bedroom LG, recycle=false, action={ct=345, alert=select, bri=254, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Bedroom, lights=[5, 51, 52, 54, 55, 56]}, 3={sensors=[], name=Bath2 Vanity LG, recycle=false, action={xy=[0.4450, 0.4067], ct=346, alert=select, sat=121, effect=none, bri=254, hue=8594, colormode=ct, on=true}, state={all_on=true, any_on=true}, type=Room, class=Bathroom, lights=[43, 9]}, 4={sensors=[], name=Bath 2 LG, recycle=false, action={ct=247, alert=select, bri=254, colormode=ct, on=true}, state={all_on=true, any_on=true}, type=Room, class=Bathroom, lights=[59, 60, 61, 63, 62]}, 5={sensors=[], name=MasterBath LG, recycle=false, action={ct=366, alert=select, bri=254, colormode=ct, on=true}, state={all_on=true, any_on=true}, type=Room, class=Living room, lights=[2, 1, 53]}, 6={sensors=[], name=Desk, recycle=false, action={xy=[0.2317, 0.0856], ct=500, alert=select, sat=254, effect=none, bri=254, hue=49791, colormode=xy, on=false}, state={all_on=false, any_on=false}, type=Room, class=Bedroom, lights=[13, 6]}, 7={sensors=[], name=Mila NL, recycle=false, action={xy=[0.4452, 0.4068], ct=343, alert=lselect, sat=121, effect=none, bri=254, hue=8592, colormode=xy, on=false}, state={all_on=false, any_on=false}, type=Room, class=Kids bedroom, lights=[17]}, 9={sensors=[], name=Upstairs Hall LG, recycle=false, action={ct=333, alert=select, bri=29, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Living room, lights=[50]}, 21={sensors=[], name=Laundry LG, recycle=false, action={ct=286, alert=select, bri=254, colormode=ct, on=false}, state={all_on=false, any_on=false}, type=Room, class=Living room, lights=[22, 24]}}
i wanted the text so I could manually add it to the app to see why its not populating, but you're saying that all of them are now available in the app or have been added?
Correct. I will be configuring a couple new groups soon as more lights show up.
You are probably already aware, but I’m posting this just in case:
If you actually have 63 lights on the Hue bridge, this could also be causing problems. That is the hard limit, but I started having problems when I was nearing 50 (Hue’s recommended limit). I’m assuming this is due to the diminutive specs (64MB RAM, 128MB flash compared to HE’s 1GB, 8GB) that the bridge has and the numerous groups and scenes I had set up.
